Old 10-06-2018, 12:09 PM
Mtgd2016 Mtgd2016 is offline
Default BPE IO540 clearance issue RV-10 engine mount
Greetings All,
I have been lurking for a long time and have benefitted greatly from this forum. Thanks to everyone who has contributed information in the past. This forum has been the best money spent on my project.
I have my brother in from out of state to help me finally hang the engine this weekend. However we have run into a problem that we canít figure out. So, I am looking for some help from the brain trust regarding install of the BPE-IO540 in my RV-10. It has the cold air induction.
When the engine is in place with the Lord mounts installed, the back of the engine is resting firmly on the bottom cross member of the engine mount. Also, the the Lord mounts look like they are distorted upward. This leads me to believe that the engine is displaced upward because of the mount cross brace.
It looks like I need to have a different geometry for the cross brace in order for the mount to clear the engine. But I know that others have used
Has anyone run into this problem?
Any help would be much appreciated.
Thanks in advance.
Mark Russell
Based at KAPA
RV-10 N14BV
Trying to hang the engine
Cell in 303- four seven five -nine five five seven
Mark Russell
Denver, CO
RV-10 build in progress
Old 10-06-2018, 12:18 PM
Do a search in the -10 subforum for engine mount clearance or words to that effect. This problem has been solved before.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-06-2018, 12:25 PM
Default Thanks for quick reply
Did a search and did not find this issue.
Could you point me to the thread?
Mark Russell
Denver, CO
Old 10-06-2018, 12:40 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Are you possibly using the smaller Vans Lord mounts with the "big hole" engine mount ears?
Stolen internet pic...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-06-2018, 02:06 PM
Default Thanks again for the ideas
I checked the match between the ears and the Lord mounts. They are correct.
Looks like I need to modify the mount geometry. Researching that now.
Mark Russell
Denver, CO
Old 10-06-2018, 02:26 PM
AviatorJ AviatorJ is offline
If memory serves me right I believe BPE has to modify the engine mount to accommodate the cold air induction setup.
Justin
RV-10 Quickbuild 'Final Assembly'
http://operationrv10.blogspot.com/
Donated for 2018
Old 10-06-2018, 02:47 PM
MElstien MElstien is offline
Default The Engine Mount needs modification
Send it to Barrett. They will modify the mount.
Michael
Builders Blog http://elstien.us/wordpress/
Northern NJ
RV-10 Builder
Tail Kit delivered 6-2013
Started building April 2014
Empennage completed
QB Wing and Fuse Delivered December 2015
Finishing QB wings on September 2018
Dues Paid through 2018
Old 10-06-2018, 03:39 PM
Default Yes
The cold air mud toon REQUIRES that the mount be modified. Barrett can do it no problem.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-06-2018, 05:03 PM
Jesse's Avatar
Jesse Jesse is offline
The bottom cross bar needs to be replaced with a curved one to clear the sump. This was an issue and fixed established years ago, but hasnít been talked about recently that Iíve seen.
352-427-0285
jesse@saintaviation.com
Old 10-07-2018, 07:44 AM
RV10Pilot RV10Pilot is offline
If your engine mount is pre 2007 you most likely have a straight cross bar on the bottom of the engine mount. Vans made a change to the welding schedule and geometry of the engine mount after 2007. See this service letter. http://www.vansaircraft.com/pdf/10_motor_mount.pdf
Tim documents his issues with the mount on http://www.myrv10.com and Deems on his construction log http://www.mykitlog.com/users/displa...g=27031&row=45
This is what the mount looks like pre modification
and post mod
