Old 05-11-2012, 07:07 AM
s24789 s24789 is offline
Question Fuel flow on takeoff
Looking for other's experiences. On take off we are seeing 13.5 max fuel flow in our carburated o-360 and fixed pitch prop in our 7a. We are also seeing no fuel coming out of the fuel drain in our gascolator mounted on the lower right firewall. We do get flow when we turn on the boost pump. Has anyone else experienced this issue. I am wondering if a vent restrictions keeping us from both seeing fuel at the gascolator drain and also restricting our fuel flow.
Thoughts ?
Phelps
Kevin Phelps
Paid thru Dec19
RV-7A flying N782WP
Stuart, Fl
Old 05-11-2012, 07:08 AM
Sam Buchanan's Avatar
been here awhile
Thoughts ?
Phelps
What you are seeing in regard to fuel flow and the gascolator is normal.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 05-11-2012, 07:17 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I agree with Sam on the Gascolator - you won't get any flow unless you have the pump turned on.
For your measured fuel flow - have you calibrated the fuel flow system yet? The factor "constant" is oftentimes off by 20%, and you have to play with it by measuring how much fuel you put in after a flight, then tweaking the constant. It is an iterative process, and can take awhile to nail it.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default .1 gph per hp at max power full rich fuel flow
The rule of thumb of .1 gph per hp at max power full rich fuel flow seems to be pretty accurate.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with almost 2,000 on the hobbs!
Race 771
margarita!
Old 08-01-2012, 03:39 AM
Paul
Hi Paul thx, yes we have calibrated the red cube. Using Mike Bush's plotting website we generally see 410-420 F at sea level 90 F take off and around 14-15 gph Wf in take-off. After a couple thousand feet with WOT the CHTs settle down. Still wondering if we are not getting enough flow for takeoff. Thoughts?
Phelps
Kevin Phelps
Paid thru Dec19
RV-7A flying N782WP
Stuart, Fl
Old 08-01-2012, 04:52 AM
noelf noelf is offline
My set up is O-360, Fixed Pitch, field elevation is 614 ft.
Seems about what I am seeing. Take off run is 13GPH, WOT RPM starts at 2130 and increases as the ground run speed increases. Red cube installed between gascolator and carb.
To drain any fuel out of the gascolator, I have to select one of the tanks using the fuel selector valve. No fuel flows if the selector is in the OFF position.
Noel
RV-6A N6NF
tip-up
flying
Old 08-01-2012, 04:53 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Kevin
Aside from fuel system anomalies and measurement errors, the following is not negotiable in general terms, +/- 5%.
Fuel flow at sea level and ISA is HP/10 in GPH, in your case I assume 18 GPH.
With a fixed pitch prop you may have 85% rpm thus 85% fuel flow, so around 15-15.5 GPH.
CHT on take off should be in the 350-375 F range, if not get your fuel flow right first, then fix your baffles.
Any questions, please ask.
David
Old 08-01-2012, 11:46 AM
N743RV N743RV is offline
Default 15.1 to 15.3 gph at Takeoff
I've just checked the digital records of my RV-7a with a 180 hp Mattituck IO-360 M1B. I have a Hartzell constant speed blended airfoil prop. On full throttle takeoff at my fuel flow ranges from 15.1 to 15.3 gph. My airport (KLVK) is at 400 ft msl and the temperatures I looked at ranged form 48 to 90 F. My fuel red cube fuel flow device is pretty well calibrated (usually well within 0.5 gal at fillups).
This seems to be more than than +/-5% off of the range of 0.1 gal/hp.
Old 08-01-2012, 12:02 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
My -9A (IO-320 160 hp - Hartsel) reads 17 gph on climb out. EGTs 1340's, CHT 380's. An -8A I recently flew (IO-360 / Hartsel prop) reads around 17-18 gph also. I think the 13-15 gph folks are running on the lean side...
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 08-01-2012, 10:29 PM
RV10inOz's Avatar
You have something not right, either fuel flow measurement or your fuel flow.
One or the other. Either way get it fixed.
18GPH please +/- 0.5 GPH is the aim. If it gets to 5% you need to tweak.
