Today on boot-up the EMS was missing from the SkyView screen. I was able to switch EMS on and it operated fine and then it disappeared on shutdown.
After delving into the set up are of SkyView I found that I had to select EMS on a boot up which I did and which fixed the problem.
My question is why would this happen?
At home it occurred to me that my SkyView used to provide a caution after it had detected that fuel had been added and I've wondered why it went away. Reading the installation manual at home I saw that I can go in and select the added fuel detection on and, as with the situation I noted above, with EMS not booting up on start, I wonder if this too has somehow been switched off? Again it's not something I've done and I'm wondering why.
Any help would be appreciated. Thanks!
