wyoflyer
The fuel pump on my RV6/0-360 has been flucuating quit a bit lately and generally trending downward, pressurewise. Flew yesterday and happened to glance at the pressure gauge and it was at 1 lb.! Turned the elec. fuel pump on and pressure came up right away.
Decided, that's it, time for a new fuel pump (this one is brand new with 50 hrs.) Removed the cowl and started removing hoses etc. from the pump. I have Van's primer set-up which runs a small copper line from a T fitting on suction side of pump to an on-off solonoid running to cylinder heads. In the process of removing the flared nut from this fitting, the flare/sleeve assembly fell on the hanger floor. Deciding this could have well been the problem, I reflared the copper line, reattached it to the fitting and also supported it closer to the fuel pump..went out and flew, and problem solved. Pressure back up to almost 5 lbs. all the time and steady......The scarey part though, is when I thought back to when I applied elec. fuel pump. Fuel had to be spraying down onto the exhaust.....not a good situation. I left the electrical pump on for the rest of the flight, thinking I would be safer. Thought "maybe" I could detect a faint smell of fuel but wasn't real sure, so just kept the pump on.....not a good situation.
Just a heads up on something to check when you have your cowl off next time. The line going into the pump looked completely normal and I guess the best way to check something like that would be to turn on elec. pump with the cowl off and look for leaks and/or manipulate the small copper tubing at the fittings. Fly Safe!
Dave Mader
RV6/50 hrs.
Dave Mader
RV6/50 hrs.
