Propellers Inc
10433 S. Leisure Drive
Hazelhurst, WI 54531 Phone & Fax: (715) 356-6856 or (800) 776-7357
USA e-mail:
[email protected]
LEARN MORE ABOUT BICAMBERED? AIRFOILS AT:
www.bicambertechnology.com
MORE BITE ? LESS BARK
Felix Propellers Inc supplies BicamberedTM (quiet) propellers developed under license with Bicamber Technology LLC. This airfoil substantially reduces prop noise, increases thrust efficiency and is remarkably smooth. This new design enhances our reputation for the smoothest operating propellers customers have experienced.
Our mission is to provide propellers that exceed all others in; smoothness, quietness and efficient performance.
Excerpts from user reports:
Cygnet, 2,000 cc - 67 HP Volkswagen. There is much less noise at any power setting. Take-off roll is 1/3 shorter. Same top speed delivered at 50 RPM more. Climb is 800?/min., increased 300?/min. This is the smoothest running prop of the six I have had on my aircraft. Z.B. Sarnia, Ontario, Canada
Bucker Jungmann, Lycoming IO-360, 200 HP. More acceleration, better roll -out, improved rotation performance. Slightly quieter in cockpit, quieter from ground. Snaps better, increased vertical performance. T.M. White, GA
RV-6, Lycoming O-360, 180 HP. Better thrust at low RPM. Cruise prop ? hard time to get to 2,700 RPM. Lower cockpit noise; lower noise on ground ? when taxiing, etc. R.N. Prescott, AZ
CM-30 Longeze ? Lycoming O-360, 220 HP. Two blade Bicambered? Felix Propeller compared to competitor?s 3 blade - Better climb, 13 MPH more top end at 250 RPM?s less. Manifold pressure down at all RPM?s, fuel economy improved for 130 knots extra range, much quieter and very smooth running.
W. Clark, Daytona Beach, FL
RV-4, Lycoming O-320, 160 HP. Better performance than previous prop. Lower noise in cockpit, quieter from the ground. More static thrust. The ground run is shorter. R.B. Stroudsburg, PA
Here are typical comments from customers for standard airfoil Felix Propellers for several types of homebuilt aircraft.
RV-6, Lycoming O-360, 180 HP. I am impressed in your propeller it runs very smooth and I really like it. TAS, 201 @ 2.700 RPM, 8.500' MSL. Climb from brake release to 5,000 ft at 105 MPH - 3 min. 13 sec. M.J., Ostervala, Sweden
Cassutt, Continental, O-200, 100 HP. Following is a performance report on the 58 X 72 prop that you built for me. Static RPM 2,300. The prop is performing very well. It runs a little smoother than the 60 X 66 (other make prop) it replaced. The rate of climb is about 150 - 200 FPM better. Take offs also seem to be better although I don't have any exact number for that. Top speed and cruise speeds at the same MP are about the same. but RPM is 150 - 200 less, - what I wanted. ROC 1,400 FPM @ 1,000' to 3,000' density altitude. Max speed 207 MPH, 3,125 RPM 27" MP, 2,500 pressure altitude. R.G., Pella, Iowa
Flybaby, Continental, C-85. My cousin and I thank you very much for making a great prop that exceeds our expectations and performance requirements. Static - 2,100, top speed - 115 to 120 MPH @ 2,500 RPM. C.R. St. Paul, MN
Lancair 320, Lycoming O-320 modified, 168 HP. Static RPM 2,000, but can't hold long with brakes, 3 to 4 seconds and it starts moving. Never saw an airplane engine run so smoothly. G.M., Covington, VA
Thorp T-18, Lycoming O-320, 160 HP. Static 1,900 RPM @ 28" MP. IAS Cruise, 165 MPH, @ 2,200 RPM, @ 22" MP. IAS max, 190 MPH @ 2,500 RPM, 25" MP. Climb 1,400'/min @ 110 MPH, 1,500' MSL. Compared to previous prop, climb with Felix prop is slightly improved, cruise improved 7 - 9 MPH. Felix prop is much smoother. This is about the most vibration free aircraft I have flown in 9,000 hours of piston engine aircraft time. I have flown in rain several times and leading edge shows no sign of erosion. Appearance is like fine quality furniture. Looks great and flies great. I am building another aircraft and a Felix propeller will be my first choice. Fuel economy has improved from 8.5 - 9.0 GPH to 7.5 GPH T.O., Lakeland, MN
Wittman Tailwind, Lycoming O-235C, 108 HP. Static 2,250 RPM @ 28"MP. IAS cruise 155 MPH, 2,500 RPM. IAS max, 3,000' MSL, 168 MPH, 2,700 RPM, 26"MP. Climb 1,000'/min @ 100 MPH, 3,000' MSL. RPM at 100 MPH on climbout was 2,300, picked up another 75 RPM when leaning. Speed runs done at 1,110# take off weight. Felix prop smoother running, max RPM's 100 higher. Prop was carved with an excellent finish. Very smooth propeller delivered as promised. I have 25 hours on prop now. D.A., Dayton, Ohio
Pietenpol Aircamper, Model A Ford, 45 HP. Cruise 71 MPH @1,800 RPM. Picked up 6 or 7 MPH. Climb out RPM 2,000, same as before, but climb is improved. Smooth running at all RPM's. D.R., Warrens, WI
LongeZe, Lycoming O-360, 180 HP. Static RPM 2,300 @ 25" MP. TAS cruise, 190-195 MPH, at 5,500' MSL, 2,600 RPM @ 20"MP. TAS max 205-210 MPH, at 5,500', 2,800 RPM @ 24.5"MP. Climb 1,800'/min., 90 MPH, 3,200' MSL. Felix prop gives better take-off, climb, engine and prop smooth at all RPM's. H.E.C., Pampa, TX
RV-4, Lycoming O-320, 150 HP. Static RPM 2,250. IAS cruise 150 MPH (GPS reading 175MPH). IAS max 155 MPH (GPS reading 182 MPH). Both at 6,000' MSL altitude, and at 2,500 and 2,700 RPM respectively. The Felix propeller is superior in overall performance and smoothness, compared with (other make prop) I was using before. The workmanship on the Felix prop was excellent, fit of the hub was good. Being a machinist, I do appreciate the precision workmanship of the Felix prop. My RV-4 is smoother than it was before, and the performance is better. B.G., Trona, CA
