Mark Bolton
Active Member
From Van's Parts Catalogue
The kit I have was manufactured in the late 80's and I am presently looking at the proximity of the carby to the inlet bump in the cowl. I cant see any way I can fit a FAB in there since there is a cuppla inches only clearance there.
From the above it seems possible that the cowls for the "OLDER RV3/3" are too tight. Has anyone been down this path before? I am not that happy with the cowls that I have since they have a few cracks and the firewall fit is a bit scrappy. Maybe it would be easier to buy a fresh set of cowls?
THX in anticipation.
Filtered Airbox - Vertical Draft
Standard FAB (Filtered Air Box) System Filters Air to Engine
Offers all the advantages of a ram air induction system but with an efficient filter. Excellent manifold pressure recovery for maximum power and economy. Provision for alternate air may be adapted to carb heat. Requires cowl modification when retro-fit to older RV-3/4. Order the system that fits your aircraft, engine and induction device.
