KJBSouth
Were you ever so frustrated by a build problem that you wanted to use a three pound sledge hammer on aluminum?
Specifically when dimpling the most forward rivet hole in HS706 where the squeezer would not fit between the flanges? And, you didn't want to lay out the bucks for a thin die or grind down your C-frame?
Care not brother. Grab your 3/16" drill bit and two chunks of 1/8" steel plate. Let the chips fly.
When you're back in control, make a setup like this and call in your trusty sledge. Careful, don't hit that finger.
Ahh, the sweet sight of success. Enjoy.
The idea for this came with Vans airfoil practice kit. Thought you might enjoy the photos.
