Tailwheel notches against fork
Mnemonics
Member
Hi,
I'm building an RV-7 and are installing a standard Van's Tailwheel.
The assembly consists of a Bolt with 2 washers that should be on the outside (according to the drawing).
However if I assemble it that way, the protruding edge touches the fork.
Is that normal?
Only when I insert a 616L washer on the inside the edge doesn't touch the fork.
Is this normal?
Marcel
