I am trying to install a new PMag on the 390. It came with one and I am installing the other one. I note the gear in the motor has 2 dots around the teeth where it looks to be timed. But the PMag has no dots on the gear. So I put it in and tightened it down. Without any timing involved.
Is this correct? Is all the timing set by the "blow" method described in the manual?
Thanks, Larry
Thanks, Larry
