On the flight home from Sun 'n Fun, I discovered several issues with my plane and I am trying to determine if I need to dig deeper for potential other issues yet to be discovered.
The morning that we left, there was a pretty bad thunderstorm that came through. We had one lightning strike that was so close, we felt the ground shake. Is it possible that the proximity of the strike caused these issues? If so, would grounding the plane while parked outside help in the future?
- TruTrak AP roll servo is no longer executing roll commands. It will engage, but just holds the stick in whatever position it is in. Pitch and Yaw still operate correctly. Continuity has been confirmed between the control head and servo.
- One or both of the TCW heater actuators was in the open position. A recycle of the control corrected this.
- GTN 650 was registering touches in the incorrect location. An in-flight reboot corrected the issue.
- Aveo tail strobe/position light failed. Bench testing confirmed.
