ringlasergyrosandwich
Member
More photos will be posted to my Builder's Log: https://eaabuilderslog.org/?blproject&proj=7XHlh0tiH
Above this line is the most up to date information/pictures
Below this line is the legacy first post
Hello, I am recent addition to the Vans Air Force community. I earned my PPL in March 2019, and have been working on my instruments rating based out of Lee Airport (KANP), Annapolis. For years I've been researching options for home building and finally settled on the RV-14A. My work space will be my detached garage, which has room for two cars and an attached room in the back for most of the work (double door connects rooms for easy of transport). I'm in the process of putting together some wood workbenches and figuring out how to lay everything out.
I recently took an EAA 2-day course on "RV Assembly" so I finally understand the basics of riveting and the tools that are needed to build an RV. I have almost none of the required tools at this point. For first time builders, is it recommended to get a comprehensive RV tool kit from one of the manufacturers on Van's website? Also, why are there so many tools/supplies that are "RV-14 only"? It seems a bit strange that RV-14 has such special needs compared to the other models.
I plan to use this thread to document my progress, share some photos, etc. My local EAA Chapter (571) has several home builders so I plan to discuss my progress with them as well. Other than tools, I think my first challenge will be figuring out how to be home to accept delivery of the tailcone (not ordered yet). I'll hold off on ordering the empennage kit for a little while longer while I finish the woodworking.
