Go Back   VAF Forums > RV Firewall Forward Section > Traditional Aircraft Engines
Old 08-12-2018, 05:08 PM
wjb's Avatar
wjb wjb is offline
Default Interference between prop governor oil line and PlanePower AL12 alternator
Hi VAFers,
I'm installing a PlanePower AL12-60 alternator on my IO-360-M1B and find that the body of the alternator contacts the prop governor oil line (aft mounted prop gov) when I install the belt over the flywheel and alternator pulleys.
It seems that it would require lots of tension to stretch the belt to the point where the clearance would be acceptable.
Is this a case of stretching out the new belt, or would a longer belt be better? I'm using the one that came in the box with the alternator (Dayco 15355; 35.5")
Bill Bencze
N430WB RV-7 #74152, tip-up. Running out of garage projects ... waiting for the hangar (any day now!)
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 08-12-2018, 05:16 PM
Stretching a new belt might take a WHILE---so take the belt off, position the alternator, and see what length NEW belt you will need. Make sure the alternator will clear other things, like the cowling, baffles. Sometimes changing 1 accessory can create several other issues.
Tom
Ridgeland, SC
Old 08-13-2018, 08:23 PM
Wunderon's Avatar
Wunderon Wunderon is offline
i got a dayco 15358 which I think will work. 15360 a touch big for me.
Dave Grimmer
RV8 N46LG for Lynda
Edmonds WA
paid 2019
Old 08-13-2018, 08:49 PM
BillL BillL is offline
Default I found the same issue.
I bent the line a little closer to the case (block of wood and a hammer YMMV) and the result was a small gap (1mm) between the alternator-line-case. 40 hrs with regular inspections indicate that it is working. Thankfully, the parts don't move that much.
The 15358 belt is a good idea too.
Edit 8-15-18 - I looked at mine again. Note (below) the adjustment slot has the bolt near the end. I used the standard belt, as the adjustment range might not accommodate much extra length.
Let us know how yours works out.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 08-19-2019, 02:53 PM
Wunderon's Avatar
dayco 15358 too big for the adjustment arm as you suggested Bill, ended up using the supplied 15355, which grants a mm or so clearance from oil line when torqued
Dave Grimmer
RV8 N46LG for Lynda
Edmonds WA
paid 2019
Old 08-20-2019, 06:16 AM
Default No motion/no contact
Good to hear, Dave. Mine is about that distance and repeated inspections in Phase I showed no contact of the parts. None at 80 hrs for annual either.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Shrunken Exit = ??
No Photo? => PM me.
Old 08-21-2019, 01:51 PM
rapid_ascent rapid_ascent is offline
Would a slightly longer belt provide more clearance?
Ray Tonks
2018 Donation Paid
Titan IOX-370 on order
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
