RV-3 parking arrangements
After some discussion with Randy, we have worked out the parking arrangements for RV-3s at Oshkosh. We have designated a spot for parking all the -3s together. It will be on row 320, and there should be enough room for at least 10 or so aircraft. For those of you familiar with the layout of the grounds, Knapp St road is the north-south road that runs the length of the convention grounds and cuts the RV parking area (Area 51) roughly in half. Row 320 is the first row to the west of Knapp St. It is directly to the east of where the large Falcon Flight group was parked last year (and will be this year.)
A couple of things to keep in mind:
While we will make every effort to keep this area reserved for RV-3s, parking at Oshkosh is always first come, first served. If the grounds will up quickly (as they always do) then we may be forced to use these spots for other RVs. I will say that, based on past experience, if you are not on the grounds by the close of the field Sunday night, then all bets are off. It fills up that quickly. That is not to say that we won't find you a spot somewhere with the RVs, but it might not be with the rest of the -3s.
If you happen to arrive at a busy time (which could be any time on Sunday or Monday) and especially if you hit the parking area in a gaggle of 4-5 other RVs, then there is a chance we might be too busy to pull you out to park you with the -3s. If that is the case, please just park where we put you, wait until the dust settles and approach one of my VOLUNTEERS (felt the need to emphasize that) and inquire about moving. We will do our best to accommodate you, just please keep in mind that you are at the worlds busiest airport and there may be delays.
Keep in mind that this reserved area is for RV-3 PARKING only. If you desire to camp with your airplane, than you will have to park in the Homebuilt Camping area which is to the west of Area 51.
No special signage is required. Simply show your HBP or HBC sign to each parking VOLUNTEER that you see and we will get you to your spot. Not sure about the signs? Now would be a good time to brush up on the Notam, it is all in there.
That's all for now. Any questions, feel free to contact me directly.
Looking forward to seeing everyone.
