I need to build a rolling wing cradle for my spars and plan to use Mouser?s design. This is 28? in diameter which is about 1-2? too wide to fit between my door!
Can anyone who has used / built a cradle advise what would be the minimum workable diameter? (For instance don?t want to put the wings too close and the ailerons hit each other etc)
Has anyone made 2 seperate cradles? This way you could work on the skins without having to remove one wing from the other side of the cradle to get access? (These may end up too thin and be unstable).
This was the cradle that would work well:
https://www.myrv14.com/buildlog/20130210/RV1420130128-204158-006.html
Thank you!
Thank you!
