Which mod?
Hi,
I just ordered mod, once I receive I will send update on install.
Wonder if Vans is installing this on their 9A?
I decided to do something slightly different. The slotted holes on the vertical stabilizer mounting bracket don't seem to provide the bolt head enough surface area, and that is probably why cracks can form here. I put some larger fender washers under the heads of the bolts.
Of course, this will be looked at carefully during inspection time.
awesome!
What bolts will you use for the new drilled holes? Thats what I want to know and whether you have to replace the existing bolts with longer ones to accommodate the plate.
I may just order this too depending on your installation success.
