chris mitchell
Just now working on my new fuselage kit and would be grateful for some clarifications or even to be pointed to the right place in the plans/instructions.....
Here we go:
Intersection of top longer on and aft bulkhead F412. I could cut the horizontal web of the longeron away where it would go over the top of the bulkhead or I can modify the bulkhead a little - is there a right answer? I am wary of removing metal from that area of the longer on as the angle that will secure the VS has to bolt through it.
Dimensions ( in boat speak I guess it would be scantlings!!) for the various longhorns on the aft and forward fuselage. At least the main ones are clear - if only because they are so long! I'm guessing that all longhorns should be 1"x1", 0.125?? But does it say that anywhere?
Intersection of forward lower longer on that runs from the engine mount weldment back to F-404 - how does it intersect with F402? Looks like it should have a notch and adjacent joggle....
Firewall cutout for prop governor - anyone ever had any problems with the recommended cutout not being the right size/large enough? Does one size fit all?
So far I have the bulkheads (or formers if you prefer) clamped to the jig, with longhorns bent and ready to clamp in place, but need to resolve the F-412 issue and notch for the F-411 bars.
Many thanks for help.
Chris
Here we go:
Chris
