I have an update. I sent the altenator back to pp. I got a call monday that they recieved it. I was told it was all wore out on the altenator, never seen one so bad. WHAT??? I had the back tore apart and the only thing wrong was the wires comming off the stator, the windings on the back housing. the bearings were nice and smooth and tight, the brushes were wore down a little but otherwise looked good. Anyway I just gave them my CC and they sent the new one back to me.
I called this morning to make sure they put the spacers on the new one. Than I asked about things because I'm feeling a little sick about all this. The guy I was talking to, name was dick, come back at me and said they had the best warrentee in the business, I replied back, ya so good that you won't help me with being a few days out of your warrentee, you see I had 2 years and just under 60days on this altenator, ya ya I also have 515 hrs on the thing.
anyway he tries now to tell me that hard landings will cause this, don't even go there, I don't even sqeak the tires when I land. He gives me the speach on belt tightening, I come back with, why not put in your instructions how to adjust the belt, he gives me this thing that a certified mechanic knows the proceedure, I come back with, your working with the experimental end of things, we builders are doing this in our garages. why keep this a secret, tell us. On and on we went. Finally I tell this guy, you know how I found out where to find the problem in this alternator, he is quiet. I found out about it on VAF, he is confused, who or what is VAF. I said that is Vans AirForce. Oh, he said. Well we have a great product, there is nothing wrong with it. I said, I desagree with you, this problem has happened before, broken stator wires that is, that is why I tore the altenator apart to look at those very wires. I feel you have a design problem there and it needs to be corrected. Well that went over like dung in milk. this guy is not going to listen. I ended the call and just am going to have to live with another altenator that is probably going to fail again with the same symtoms and problems. For now I have to go with the satisfaction that I will have a new altenator and start at square one again. In the mean time I guess I'll have to do the alternative and have a sequence for alternator failure, and make it so I can fly to my destination and repair after I land. What a deal here.
Hope I haven't upset anyone, but I feel this needs to get out. THere is a problem with this altenator on the stator wires. They say it's vibration. well I said it before, these engines do vibrate, hence the sensor for fuel and oil are on the firewall. So I think PP needs to adress the problem and fix it. Not us trying to make our engine vibration free.
