Richard Connell
For those of you that have chosen to attach your tips using piano hinge, how have you installed the rib in the tip?
I imagine there is conflict between the hinge and the rib if you extend the hinge to the rear of the wing skins. Particularly on the top.
I?m also expecting to swap the ribs so the flanges are outboard to allow insertion of the pin.
Richard
Richard
