Galenkillam
Member
I will be a newbie to IAC competitions this summer and understand I need drilled bolts with castle nuts on the control surfaces. Can anyone confirm that AND are there any comments about replacing mine on my 8?
This is a bit like primer wars. I know an A&P who won't sign an annual unless all lock nuts are replaced by castelated nuts on drilled bolts with cotter pins. Then again I've seen cotter pins fail.
I thought 43.13 said that if the bolt doesn't rotate a lock nut is appropriate. It's probably a question that is difficult to get agreement on.
Newbie question. I come from motorcycle road racing background. We safety wire everything. I would drill through the side of a nut on a corner to run safety wire.
J
Why isn't more safety wire used?
What RVDan said. I opted to install castellated nuts and cotter pins in all moving control areas.
From 43.13:
7-64. SELF-LOCKING NUTS. These nuts
are acceptable for use on certificated aircraft subject to the aircraft manufacturer’s recommended practice sheets or specifications. Two types of self-locking nuts are currently in use, the all-metal type, and the fiber or nylon type.
a. DO NOT use self-locking nuts on parts subject to rotation.
b. Self-locking castellated nuts with cotter pins or lockwire may be used in any system.
