Old 03-29-2018, 10:10 PM
mciaglia mciaglia is offline
Default Fuel Lines & Brake Lines
I am getting ready to tackle the brake and fuel lines. I know some people have upgraded to stainless steel lines from Bonaco / TS Flight etc..
Do most people just forget spending the time making the solid lines and order SS?
Is it better to spend the time fabricating the solid lines so they can be used to determine the lengths for the stainless steel?
Kinda exciting moving into something other than airframe assembly and working on systems.
Thanks in advance
Dr. Mark Ciaglia
Houston, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 03-29-2018, 10:30 PM
Most people use the stock aluminum lines. They take 5-10 minutes each to fabricate and are identical to similar lines on many certified aircraft. They are also lighter and less expensive than the SS lines.
I suspect you'd spend almost as much time spec'ing out and ordering SS lines as you would spend making the stock ones.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-30-2018, 05:02 AM
Auburntsts's Avatar
I used rigid tubing in the cabin. For the fuel lines from firewall to tanks I followed the plans except I didn’t use the stock tubing—I upgraded to 5052.
For the brakes I used the stock tubing to the fuse fitting at the landing gear weldment. From there to the brakes outside the fuse I used SS braided line from TSflightlines and highly recommend them (both the company and the lines).
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 03-30-2018, 06:15 AM
Jasonm Jasonm is offline
Stainless braided lines the entire way from TSFlightlines. Tom was fantastic to work with!!
Jason McKay
"Phase 1 - 05/26 - 07/02"
2017 Dues Paid
Old 03-30-2018, 06:51 AM
DanH's Avatar
DanH DanH is offline
Aluminum tube for fixed lines, teflon/SS when connected to anything that moves.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-30-2018, 07:40 AM
Electrogunner Electrogunner is offline
Default Flex
Ditto on above. I used hardlines in fuselage and used teflon/SS to connect the wing tanks and down gear legs to brake calibers.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 03-30-2018, 08:02 AM
rleffler's Avatar
rleffler rleffler is offline
I concur. I couldn't make a decent flare if my life depended on it, so I went with lines from Tom.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-30-2018, 08:21 AM
9GT's Avatar
9GT 9GT is offline
I preferred to keep it light and fabricated the per plans brake line system in my -10. Use a little lubricant on the burnishing cone of the Parker Rolo-Flair and don't under or over flare.
Page 17 on the link gives an example of acceptable flare dimension.
http://hhh.gavilan.edu/hspenner/iLea...esFittings.pdf
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2019
Old 03-30-2018, 10:55 AM
rocketman1988 rocketman1988 is offline
Default lines
5 -10 minutes for fabricating each line? You must have used the stock soft aluminum...
I opted for 5052 tubing in the tunnel. It took FAR longer than 10 minutes per line but then again the 5052 tubing is more rigid...
If I built another airplane, I would just have the SS hoses made. A whole lot less hassle and pretty much guaranteed not to leak.
That being said, I would give a great recommendation to Tom at TS Flightlines...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues Paid 2018,...Thanks DR+
Old 03-30-2018, 11:35 AM
DRMA DRMA is offline
Mark -
I fabricated the lines per the Van's plans with the Van's provided tubing. It took a couple of attempts to get the fuel lines in the tunnel right, but I had enough tubing to do this. While it took a lot more than the 15 minutes another builder estimated, in the end they came out well and hopefully won't leak once I finish the build.
I figure I can always switch to pre-fabricated or flexible lines in the future if I have problems, so decided to start out per the plans. I've invested enough time and $ on other additions/changes to the base plans and figure I have to limit the changes if I want to complete the project.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
