Old 04-03-2020, 03:30 PM
Pilotjim77 Pilotjim77 is offline
Default Switching Between GPS Sources to Autopilot
I wasn't sure whether to put this in the Autopilot or GPS forum.
I want to put a switch on my panel to switch between my three GPS sources to feed the autopilot. I think I need a DPDT switch (on/on/on) with a jumper to accomplish this. I'm not 100% sure how to wire this. Perhaps a different kind of switch might work better? Any thoughts or suggestions?
Jim
Purchased July 2019: RV-6 0320 Whirlwind Ground Adjustable Prop
Old 04-03-2020, 03:39 PM
I've got a couple of these... not sure if they are appropriate or which terminals to use.
Jim
Old 04-03-2020, 04:38 PM
flysrv10 flysrv10 is offline
SEND ME YUR EMAIL AND I WILL SEND A WIRING DIAGRAM.
Old 04-03-2020, 07:40 PM
emsvitil's Avatar
emsvitil emsvitil is offline
They have rotary switches to switch between multiple inputs/outputs.
Ed
Old 04-04-2020, 08:39 AM
That's an idea I hadn't thought of... will look into that.
Jim
Old 04-04-2020, 12:22 PM
Rick_A's Avatar
Rick_A Rick_A is offline
When I saw this post it reminded me once again why I like my all Garmin G3X system. When I first built my plane I had a Garmin 480, GRT displays w/ internal GPS and TT autopilot - plus switches to select AP input source. It all worked fine but when things got busy it was all too easy to get the wrong input to the AP or wrong selection on the GRT.
With my current panel, the GTN, G3X and GMC 307 work seemlessly together. I let the GTN be the navigator 100% of the time. The only time I don't use the GTN is when I "fail" the GTN on purpose.
The only "switching" I do is HDG or NAV mode on the AP and whether NAV is GPS or green needles.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 04-04-2020, 12:47 PM
Walt's Avatar
Walt Walt is offline
Make sure any switch you use has gold contacts, standard toggles not a good idea for small signal switching.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-04-2020, 01:54 PM
Walt, any idea where I might find one?
Jim
Old 04-04-2020, 02:27 PM
Switch needs depend on what the source has to offer, but in best case (say a GTN box or similar) you need to switch 3 wires - one RS232 line, and an ARINC pair. For three sources thatís a lot of wires.
Old 04-04-2020, 02:55 PM
Walt's Avatar
Look around on Mouser, you can spec all sorts of things from the menu.
