Ok, so the ECi kit O360 I built performed flawlessly on my newly completed 6A for the first 11 months. It then developed a pesky minor oil leak, which would leave some trails down the left side of the belly. We're just talking minor, less than a teaspoon from a couple of hours flight. I'd pull the cowl, wipe everything up, ground run for several 5 minute checks, spray with foot powder, then with magnaflux developer, still couldn't find any traces of leaks. Seems to only happen in the air. Did this again today and asked a knowledgeable engine kind of guy (works on volvo-pentas) and he noticed some oil on top of the #4 cylinder which looked like it could be making its way down and then leaking onto the cowl. We're just talking a film here, not a stream. Anyway, I cleaned this up so there was no trace, intending to reinstall the cowl and fly, then recheck. Just before putting the cowl back on, I noticed a couple of small dents in the #4 cylinder valve cover . Looked like someone took a punch from the inside and tapped it. Recognizing this was no good, I took off the cover and found that the spring which holds the shroud tubes in place (where the push rods go), had cracked and separated. As one side made its way from the top of the cylinder head to the bottom, it evidently came between the rocker and the valve cover, causing the small dents in the cover. This is piece LW-14995 in the O360 parts manual, if you want to refer to that. Of course the next question, what about the other 3 cylinders, had me removing those valve covers. When I removed #2, the spring was intact, but I could see a crack forming. Removing the hold down nut and then attempting to remove the spring, as soon as I touched it, it broke in two! @#$$$%!!! Same thing happened to the number 1 cylinder. The only spring I could remove intact was the #3 cylinder, and it had the same cracks!
Does anyone know of a history with this? The airframe and engine now have 115 hrs on them, with only 67 hours showing on the tach (microvision tach starts at 1500 rpm).
See the photos for info. The last photo shows the cylinder with shroud tubes in place, but no spring. The spring installs in the stud visible on the left, with a locking tab and nut.
I can just replace these of course, but something is up when all 4 fail in the same manner with no other engine issues. The nuisance oil leak appears to be from the shroud tube seal while under operation.
http://img267.imageshack.us/img267/4481/1003155m.jpg
http://img407.imageshack.us/img407/3226/1003157r.jpg
http://img828.imageshack.us/img828/6531/1003163.jpg
http://img248.imageshack.us/img248/9517/1001720n.jpg
