Old 07-29-2018, 09:23 PM
Mycool Mycool is offline
Default Bent whip antenna mounted on top
Hello,
was wondering if anyone had any input on bent whip antennas mounted on top of aircraft. Looking to weigh all the pro’s and con’s if any.
US ARMY VETERAN (75th & 1st 509th Airborne)
A&PP
RV Transitional trainer
RV9A - FLYING
RV3 “a” - Rebuilding
Wheeler Express - Sold
Old 07-29-2018, 09:41 PM
Sam Buchanan's Avatar
been here awhile
I've been flying a "slightly bent" whip on the rear turtle deck of my RV-6 since 1999 and it has worked very well. Not sure why one would want to use a real "bent" whip on top when the straighter version works so well. Seems to me it would put most of the element in the horizontal orientation which is not good for COM antennae.
The antenna on the left is the Delta Pop antenna I've used for the past several years:
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 07-30-2018, 09:55 AM
MercFE MercFE is offline
The biggest "con" is that you can't list a "pro" for using the bent whip on the top... The bend is there to get ground clearance, and sacrifices a small amount of verticality in the antenna. No reason to bend an antenna on top of the plane.
Old 07-30-2018, 10:34 AM
No reason to use one, unless you have one on hand & don't want to spend the money on another.
It won't perform as well, but whether you can tell the difference if you're not on an antenna test range with multi-kilobuck test gear is a different question.
Charlie
Old 07-31-2018, 12:43 PM
Default Attn
Ok, thank you for the input. “Attention” antenna it is. Thx for the link too.
A&PP
RV9A - FLYING
Old 07-31-2018, 08:08 PM
Charles in SC Charles in SC is offline
The bent one looks more streamlined so the plane looks faster sitting on the ground. Maybe a "pro".
Aircraft structure built.
Going at a snail's pace, life gets in the way.
Wiring done.
Engine hung.
Working on cowling.
RV 7
2019 dues paid
Old 07-31-2018, 09:28 PM
been here awhile
It will just look like somebody put a belly antenna on the top of the poor airplane....
Sam Buchanan
1999 RV-6
Old 07-31-2018, 11:21 PM
I agree, Was hoping I can use the bent Antenna and still have the same performance on the top.
A&PP
RV9A - FLYING
Old 08-01-2018, 12:15 AM
You actually lose less than you might expect. An ideal 1/4 wave whip, bent half way up, still radiates over 80% of the vertically polarized power as the unbent whip.
Old 08-01-2018, 04:59 AM
rbibb's Avatar
rbibb rbibb is offline
Pro - reduction of the drag coefficient by maybe .001 percent (a WAG not even a SWAG).
Con - less effective comm radiation pattern.
If you want to trade comm effectivity for less drag go with a wingrip enclosed antenna.
Or just concentrate on reducing cooling drag for more bang for the buck in terms of effort.
My totally, untried, and therefore, totally untested and not backed by any evidence, empirical or otherwise, opinion.
But then, offered with no expectation of renumeration in any form, or with any reason.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
