Old 07-29-2018, 01:11 PM
Dean Pichon Dean Pichon is offline
Default WAAS GPS/ADS-B question
I have decided upon the uAvionix echoUAT unit to provide ADS-B in and out for my RV-4. My aircraft has an existing GPS antenna connected to a Garmin SL-60, but I don't have a WAAS GPS source, so had planned to install the integrated (antenna + receiver) SkyFYX unit offered by uAvionix.
Now, I am second guessing myself and would like to know whether or not I could use the existing GPS antenna (or a new one in its place) with a GPS splitter to provide signal to both my SL-60 and the SkyFYX variant that requires an external antenna.
The benefit to me is that I would not need to install another antenna, and would avoid running the associated wire(s). The downside is that I would need to buy and install a splitter something like this:
https://www.gpssource.com/collection...d-gps-splitter
Thoughts or recommendations appreciated.
Dean
Old 07-29-2018, 02:51 PM
Carl Froehlich's Avatar
You answered your own question:
- SL60 uses and external GPS antenna
- The SkyFLX is an integrated GPS antenna and receiver in the one puck.
These are two different animals and not compatiable.
The SkyFLX that has an external antenna might work with a splitter, but I’m very skeptical. Considering the gross price of a GPS splitter along with odds that it would not meet the WAAS requirement I would look at other options.
If you ever plan on using this plane for IFR work, this might not be the best path.
Old 07-29-2018, 04:39 PM
Originally Posted by Carl Froehlich View Post
The SkyFLX that has an external antenna might work with a splitter, but Iím very skeptical. Considering the gross price of a GPS splitter along with odds that it would not meet the WAAS requirement I would look at other options.
Hi Carl,
Thanks for the reply. The SkyFYX with the external antenna is the one I am considering for use with a splitter in this scenario.
Every so often, I consider a major panel upgrade to incorporate IFR capability, but the task is so large given my current equipment that "throwing away" the uAvionix ADS-B solution does not bother me.
Thanks again,
Dean
Old 07-30-2018, 08:30 AM
flightlogic's Avatar
flightlogic flightlogic is offline
Default don't split
I will let you decide which avionics is best for your situation, but I don't agree with splitting a GPS signal. I know they make the splitter and charge $300. But a gps signal is very very weak by design. Splitting it further risks poor performance.
"Kindness is never a bad plan."
Work bio: Avionics tech support; ATP rated in planes and Helicopter Instructor law enforcement tactical radio systems. Blessed to fly my RV9A to work every week.
Old 07-30-2018, 03:37 PM
Itís potentially much worse than just losing half the signal. Some antennas have built in amplifiers requiring dc voltage running up the coax. Some have different gains than others (look at the mess the early 4xxW Garmins had when they used an OEM antenna). Unless you are absolutely sure you know what youíre doing I would never suggest a splitter for this application.
Old 07-30-2018, 03:57 PM
Larco Larco is offline
IIRC the GA56 NON waas antenna is quite popular and used with the SkyFYX that requires an external antenna. They can be found on Ebay or here VAF classified for not much money, far less than a spitter that will probably not work. I know of at least 2 RVs using this same set up as you with this antenna. Recommend checking with Uavionix of course.
When upgrading the 430/530 to WAAS the GA56 became surplus so they sell pretty cheap and now used on several ADSB systems like Uavionix.
Old 07-30-2018, 09:59 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Pretty sure you need a WAAS gps for proper adsb out reporting, no? Or does the SkyFyx put out a proper WAAS signal with a non-waas antenna?
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 07-31-2018, 06:58 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default G56 antenna works well with uAvionix
No issues, with several FAA reports asked for and rec'd ---- always clean. Always worked fine with Navworx, previously.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 07-31-2018, 02:50 PM
Ron
As has been discussed previously, the fact that a gps is working today, or last week, or on a hundred straight days does not mean that it will work under the worst case scenario where it is still supposed to work. e.g., Does it meet the performance spec? Almost no RV owners can answer that question. Iíd call uAvionix and ask them if their promise of meeting specs is still valid with this antenna.
Old 07-31-2018, 06:31 PM
Thanks to all for the posts. The questions, concerns, and advice have helped with the inquiries made to the various suppliers.
So far, I have had preliminary conversations with Garmin, uAvionix, and GPS Source the division of General Dynamics that makes this splitter.
The GPS splitter I'm investigating amplifies the received signal. It can be configured to use a DC voltage provided on the coax by the GPS receiver or can accept an external supply.
The Garmin aviation tech rep I spoke with said the use of a splitter in this application is common. (Though, to be honest, I have not heard from anyone who has done it.) He admonished me to make sure to get the correct voltage for the splitter. The antenna that came with my SL-60 uses 5VDC according to the drawing I found for it on the internet.
The SkyFYX unit is a WAAS GPS receiver. According to uAvionix, the SkyFYX unit will work with my installed GPS antenna. This is a key issue and I will probably have a 2nd conversation with uAvionix to confirm, once I have all the details specified for the splitter.
I need to have a deeper conversation with GPS Source to determine connector specifics, EMI issues, and so forth. I also need to confirm the 25dB of gain provided by the splitter is acceptable to both receivers. There are probably other issues I have not yet considered, but this is what make this fun.
Thanks again for all the help.
