Old 02-11-2018, 04:30 PM
Richard Connell Richard Connell is offline
Default Wingtip Hinges
For those of you that have chosen to attach your tips using piano hinge, how have you installed the rib in the tip?
I imagine there is conflict between the hinge and the rib if you extend the hinge to the rear of the wing skins. Particularly on the top.
Iím also expecting to swap the ribs so the flanges are outboard to allow insertion of the pin.
Richard
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 02-11-2018, 04:33 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Hi Richard,
Everything you need to know is right here (at least for a-7/8/9, but same should apply for a -10):
http://rvplane.com/pdf/WingtipHinges.pdf
Mike B
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 02-11-2018, 04:42 PM
Originally Posted by bullojm1 View Post
Hi Richard,
Mike B
Thanks Mike. Thatís a good reference.
I did this on my -7 so Iím up to speed with the various methods.
The problem on the -10 is that the tip rib extends further forward plus it has a reflex in it. So one needs to either shorten the tip rib flanges, shorten the hinges, or come up with some other clever solution. Curious as to what others have done to address this specific conflict.
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 02-11-2018, 05:28 PM
Bill Boyd's Avatar
Default Jumped first; questions later?
I just finished installing the hinges using Mike's excellent directions. I've put off figuring out how to install the ribs and secure the pins. I guess I was thinking it was necessary to rig the ailerons and then match the wingtip T.E.'s to them, and lock in any necessary twist by installing the ribs at that time.
If nothing else, this thread makes me think I should have looked ahead a little more at the rib installation - although this is probably an area where one could "wing it" and depart from the plans a bit without issue, as long as the wing tip closure and hinge pin capture is engineered soundly.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 02-12-2018, 05:02 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I reversed the ribs left to right and upside which leaves a space to secure the hinge rod material. This required a little trimming of the rib. I drilled the retaining bolt and safetied them to prevent them from backing out and interfering with the aileron movement
[IMG]IMG_1661 by Bill Peyton, on Flickr[/IMG]
IMG_1669 by Bill Peyton, on Flickr
Bill Peyton
RV-10 - 950 hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 02-12-2018, 06:36 AM
Scott Hersha Scott Hersha is offline
I cut off the part of the rib flange that coincides with the aft part of the skins, and made a new flange section that points outboard in those two areas. These pieces need to be spaced away from the fiberglass slightly so that it sits on top of the hinge half where it is riveted through the hinge half into the fiberglass. This allows the hinge pins to nest nicely in the inside apex of the inboard facing rib flange. I mounted a couple hinge eyelets to use as guides to ease attachment, and there is a slight load on the pins with a 90 degree bend in the aft end so that they snap into the tooling hole in the back end of the rib to hold them in place. I can remove a wingtip in 30 seconds with no tools.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
