ADSB out
olderthandirt
So the questions ADSB out from Dynon or Van's....I have the transponder but would like to upgrade to ADSB out...20 20 compliant...which place to buy??
You just need to swap the GPS250 for a GPS2020 and change the serial port setting. Either source should work fine.
Vans sells the kit with wiring & pins already attached (and instructions) - can take everything apart, install, make a few changes in Skyview menus in an hour or so if you don't run into snags.
ADSB 20 20 compliant
I'm not sure if the price has changed, I thought it was around $500.00 but when I looked at Dynon it said $750.00 can't find price at Van's...thanks for help...
