F-466 Trailing Edge Fillet???
Jvon811
Missing piece? F-466 Trailing Edge Fillet???
A friend of mine recently purchased an RV-4 and after getting it home and further inspection, we've discovered his airplane is missing a part that mine has... It's the fillet between the fuse/cockpit area and the tailcone of the airplane.
nEFeYAB0amHhYS_v9e6yusO4qOCbe7QwwQ4TnMInsJv9MTuXhwPivu7TOYjzPa1rEEBTVv5AuqIH7TOgvoUvGkfSl0l5ZM4R456oZsaevc1RH3Zni_2kj6irP1g3T752mYrdj1h9LGhcCgXhTaOVMoqeCc3H_Ycdw1_GxjonlftnK2dgugcFCCWQYoh6QtRbOO24yC3h9BhGiBv2PTG1Yi6n4kfUufVN9a4W_zALY92yIVMBzOEAKmoI8lyJRt8ynNEKBUU9WdEAfUBJw2XVUrTAJZG2eHDUqNw2y2nSLJKNlz_5V4qlVrwoc-NRBgAB7pzLYaWttxltW8Xxd_EE_n2QPXohs3PkKdZX91RfSi8tAt50zRI5hkpvWhKL4WQCpo4yqbd37FjMOkqEjt4Zf_Y3bQakCagkWez3YYnkMvsf_Rzzcp8kqU-OdsT6EFbaz-ZC9Umww8vaYImCkPq8AYdwOswrsQ2WTLH5OO7691Gb3AlEJILu63HVcwxju77BaevAlczic2sCf-9fyDJl4GnUp9jzzcXzGoBK48zhtlGk67rAW7NFl4dw2F_PD1_wWRKQDkHR8TnVjwTeQlvAbNtmSWjV9DTq22F6z3Rcgovhvfxpxz9uArLCfj9-krNMvc_tXYUbcnCGvGPBAHs6cbno=w800-h681-no
I went back, looked at my set of plans and sure enough, there it is, F-466. My question is, how many (if any) RV's are flying around out there without this? Is is structural or purely a cosmetic/aerodynamic piece? My RV-4 does have this F-466 piece and it seems to have 15+ rivets holding it on making me wonder if it's structural. If nothing else, it gives my friend and I a reason to bend some sheet metal and learn some building techniques.
Just a fairing
It is simply a transition fairing with no structural value that blends the "square" fuselage to the radius of the belly skins . You could make and install one using solid or blind rivets. If I recall, its only .020" or .025" aluminum , but gives a nice clean look and better aerodynamics.
trailing edge fillet
It is actually .016. The plans call for a 90 degree bend, but is the aft portion of the fillet formed to match the tailcone?
RV-4 wing trailing edge fillet.
On our (my brother and me) RV-4, I made a cardboard model. When it fit correctly, I transferred it to .016? aluminum. I did not make to 90 degree bend as the instructions show. Mine is one changing radius bend. It looks very good. The front is a radius of maybe 1/4? inch gradually transitioning about a six or eight inch radius. I don?t have a picture of it. We built a -7A and a -4. I have the 7A here. My brother has the -4 there.
