360 Intake Tube Compatibility??
mandorfer
Does anyone know how different the intake tubes are for an angled valve IO-360 (Lycoming P/N?s 78741, 2, 3, 4) vs the intakes tubes on an IO-360-M1B (Lycoming P/N?s 42E22611, 2, 3, 4 )? I have a B1E (parallel valve / rear facing sump) that I am overhauling and need to convert it for a fwd facing sump for my RV7. I know the angled valves engines and the M1B use the same sump, but I am guessing that if I buy a used sump off an angled valve the tubes will not work on my parallel valve with the same sump. I know I can buy the superior cold air sump with tubes, but am trying to save some money. Thanks.
IIRC, If it would help to modify your sump from a rear facing to a front facing, I think this company did the conversion.
http://www.divcoinc.com/
It's been a long time since I did the research, but I *think* that the angle valve tubes are about 1/4" 'shorter' where they meet the head to allow for the larger profile of the angle valve heads. Pretty sure I've seen people use a spacer to make up the difference when using angle valve tubes on a parallel valve engine.
If you're interested, I've got a rear-inlet sump that's been converted to forward-facing, for a parallel valve engine, and I'm pretty sure I have the tubes as well. I bought it to convert a rear facing sump engine, but plans changed. I think I paid around $450 for it.
Charlie
edit: Again, IIRC, some of the rear facing sumps ('C' suffix engines?) also have the tube exits from the sump too far aft to clear some RV motor mounts. The one I have has the tubes exiting in the 'typical' location.
Thanks for the info. That confirms what I have heard. I am picking up a sump and tubes tomorrow and will see how it goes.
If you need new intake tubes and want to save a few dollars over Lycoming new, contact Clint at Vetterman. He will custom fab some for you for something like $75 each. Fits right up and no need for spacer. That is what I did going from AV to PV cylinders during my engine rebuild.
Hi0WDPbl2PQSafQ0OmMvCl7n26KfRoKuKcoF0uSUNiNzoP4NEK8vncwv_3Pfy1MjgO5Ad7VJA2qHb7u6CvybmyVudToVdhN8455gJKfGX13KWowGSUHggg2VoAcskjBiYqAw3Y01E4RSjF7hr--rB5v6f09wlvCYD21Di-oFInuA6i3ihP0GLazscRj_EjBg4CQMMHPVZ8eXSgX6jUs8EggDBJo2ivxrF0flyvayi1HWXUGxch9HZgzUHN_Qtr0-PmPvIt61DbMSTNWfbEzu_hFUPgJ72iCp4iodmf2PT1VqpA_NDwhDTm9T8bNNIdJLAohXPl804C7tadBYHZdFmDAoP6sOoi0zU2wFMPj28XlQgRSochRJRXC8uaPAb80cJekrf2kxqfWbtKK-JEjQDXj661uTJ2ysZ7ibyDQ6KYS2jZB5oUwkil-eU_NTLFvotU-oJYNm86MHxKRmnHocc0LZjfkEcHGHWFj4nR1Pu8X0SQJls9Uc0zRKhOV5sTGz3f7Pql5FPbG9gMczw_kHJZfYMJi9SqYL-JmcEb7UWIyRyzP2T-xguxQ3riKRB3jBGyt7TatsaH99NaeRAPAo_hsv1JAS0OM2olk3MewSANb_2-nJRLZy-MqyT55tlYpzUOp7e02QP-J5RFxAyjZ0e4UU2-SeXwQ=w1263-h710-no
If you need new intake tubes and want to save a few dollars over Lycoming new, contact Clint at Vetterman. He will custom fab some for you for something like $75 each. Fits right up and no need for spacer. That is the what I did going from AV to PV cylinders during rebuild.
Good call. Speaking to Clint is what made me decide to go ahead with the plan. I initially called to see if I would have any exhaust tube interference issues and he was familiar with what I was trying to do on the intake side. He gave me a few options, one of which were the new tubes you mentioned. They look well made. I'll probably go that route.
