Timberwolf
I'm starting this thread to try to get some data points for those out there with a Val Nav 2000 radio. If you or any buddies have one installed, I'd love to hear if you have issues.
I'm seeing the needle swing when I transmit on a comm radio. It is essentially unusable for an approach. I'm in comms with Val through email and they are pointing the finger at the radio install, however I don't believe that to be the case since it didn't effect the KX-155 and it happens on both radios. So for anyone else out there that has seen any such issue, please post up so we can try to sort this out and get to the bottom of it.
