David Paule
After you've flown your plane, and you're planning to fly again that day, do you do another full preflight inspection? Or if just an abbreviated inspection, what do you check?
Suppose that you spent an hour on the ground with the plane in sight. Perhaps refueling, perhaps visiting a buddy at a different airport.
And how about the run-up? Do you do a full run-up the next time, with the engine still warm?
I'm asking about normal operation - well out of the test stage.
Thanks!
Thanks!
