Hello all.
My RV7-A has a Mattituck IO-360, and a Catto 2 blade which is mounted on a 4" extension (I have the Sam James long cowl).
If I want to switch to a Hartzell CS without redoing (shortening) the cowl, what are my options?
How long is a Hartzell "extended hub"?
Thanks to anyone who can help with info.
I would call or email Hartzell. You may research all of their props:
http://www.hartzellprop.com/product_support/sitelinks_prod_appguide.htm
They make a "James Cowl" prop. Also, I think that they discourage acro with this prop.
Model: RV-4,-6,-7,-8,-9
Trade Name:
Modifier: JAMES AIRCRAFT
Engine: LYCOMING (I)O(F)-360-A1A
Propeller Model: HC-M2YR-1BFP Power: 180 HP @ 2700 RPM
Notes: O-360-A1A OR SIMILAR MAY HAVE
LIGHTSPEED PLASMA II ELECTRONIC
IGNITION. IOF-360-A1A OR SIMILAR
EQUIPPED WITH AEROSANCE FADEC;
Aircraft has a modified cowl.
Prop Setup:
Aircraft T.C./STC: Experimental
Non-HPI Items:
Hartzell Approved Items:
Placard/Restr: DO NOT OPERATE ABOVE 22 INCHES
MP BELOW 2350 RPM. O-360-A1A:
OPERATION ABOVE 2600 RPM LIMITED
TO TAKEOFF, IOF-360-A1A: MAXIMUM
ENGINE SPEED LIMITED TO 2650 RPM.
Prop Diameter: 74"
Blade Model(s):
Date:
Propeller T.C.: P43GL
Item Type Item Number Description Quantity Qty Per Comments
PROPELLER M2R10000 HC-M2YR-1BFP/F7496/SM8 1 A/C
PROPELLER M2R10050 HC-M2YR-1BFP/F7496[*1]/SM8 1 A/C
PROPELLER M2R10100 HC-M2YR-1BFP/F7496-2/SM8 1 A/C
PROPELLER M2R10150 HC-M2YR-1BFP/F7496-2[*1]/SM8 1 A/C
BLADE F7496 BLADE UNIT, ALUMINUM [6,1,11] 2 Prop
BLADE F7496*1 BLADE UNIT, ALUMINUM [3,1,11] 2 Prop
BLADE F7496-2 BLADE UNIT, ALUMINUM [6,1,11] 2 Prop
BLADE F7496-2*1 BLADE UNIT, ALUMINUM [3,1,11] 2 Prop
SPIN MTG KIT A-2476-8 SPINNER - MTG KIT 1 Prop
MTG BOLT/STUD A-2067 STUD, MOUNTING, 1/2-20 6 Prop
F7496
F7496*1
F7496-2
F7496-2*1
- V
Page 7 APPLICATION INFORMATION 61-02-59 Rev. 13 Oct/09
