ronschreck
I have about 20 PSI at idle and was getting about 55 PSI at cruise power and that has been decreasing, so I have grounded the airplane. I have replaced the oil pressure sender, insured that the oil line to the sender is clear and the orifice in the #4 fitting on the case is open. I have checked the vernitherm and the spring and ball are both OK. I have confirmed the pressure with a mechanical gage. I have capped off the prop governor line and the prop oil line fitting at the front of the case to isolate the prop. I have removed a line from the oil cooler and get a pretty good flow of oil when cranking the engine over with the starter. I have inspected the oil filter and it has no metal of any kind. None of the actions I have mentioned result in a normal oil pressure. I have emailed Mahlon Russell, who built my engine at Mattituck and he is out of touch until January 23rd!
Show season starts soon. I need to get back in the air. Any suggestions short of pulling the engine! Thanks in advance for any and all suggestions.
