Old 12-17-2005, 09:03 AM
detlef lili detlef lili is offline
Question Proseal
Hi to you all! I have used yesterday Proseal on the tanks and today 24 hours after it is still soft. Is this right? On the other hand I received the Proseal from Vans already expired (expiring date august 2005). Does this matter?
I would hate to do all the tanks once again!
Old 12-17-2005, 09:23 AM
painless painless is offline
Proseal's set time is affected by ambient temperature. Are you in an area where the temps are low? Cooler basement? Outside garage that is not heated?
Give it time. It will set, assuming you used the proper 10:1 ratio. That expiration date is not that long ago. Should be fine.
Oh....Duhhhh. I see you are in Germany. The colder temps will make your proseal set time a bit longer.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 12-17-2005, 09:47 AM
When I did my tanks, the sealant was always soft 24 hours later. I tend to give it a good week of cure time. It was also quite cool when I was doing the tanks. If you want to try to speed things up, drop a worklight into the tank bay and suspend it there...then cover the baffle area with plastic.
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 12-17-2005, 10:48 AM
rv8ch rv8ch is offline
Default Proseal setting
First time I used proseal I didn't mix it enough. I didn't read the instructions carefully. It never set. The second time, I really mixed the heck out of it, and it took several days to set. My workshop is very cool, ranging from about 3c now, to all the way up to 19c in the summer.
http://www.rv8.ch/article.php?story=20040726220023545
As a side comment - the proseal I got from Van's, even when set, is no where near as hard as the proseal on my QB tanks. I'd really love to know what those guys use down in the Philippines. It's much better, IMHO.
Mickey Coggins
http://rv8.ch
Old 12-17-2005, 12:12 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by detlef lili
Hi to you all! I have used yesterday Proseal on the tanks and today 24 hours after it is still soft. Is this right? On the other hand I received the Proseal from Vans already expired (expiring date august 2005). Does this matter?I would hate to do all the tanks once again!
My guess is your proseal is just fine. Like others have commented, ambient temperature has much to do with how long it takes for it to set up. In a production environment, differences in set up time are useful. There, proseal is mixed as A1/2, A4, B1/2, B2, B4, etc. Each mix has a different cure rate and characteristic viscosity. Often a shop foreman would make you point a heat lamp at a specific area of an assembly at a defined temperature to accelerate the cure so you couldn't use the excuse that you were "waiting for the sealer to dry!"
Even poorly mixed proseal will eventually set up but it is virtually impossible to determine exactly when since there are many variables such as manufacturer, batch, shelf life, temperature, and mix ratio.
Rick Galati RV-6A "Darla"
Old 12-17-2005, 01:29 PM
13brv3's Avatar
13brv3 13brv3 is offline
I agree that it can take a while to cure. In the past, I've mixed Proseal in paper cups, and when I'm done with that batch, I write a date and time on the cup, and leave a popsicle stick in it. You can then poke, and prod at the stuff in the cup to see if it's cured, rather than what's on your tank.
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased (yes it's cheating)
A&P - 2018 dues paid
Old 12-18-2005, 04:46 AM
Default proseal
Thanks guys, it was a great relief to read all this. And by the way, it is snowing but our workshop is heated, if not it would take maybe still longer for the Proseal to cure and my patience would drop below cero!! Happy Christmas to you all!!
Old 12-18-2005, 05:59 PM
osxuser's Avatar
osxuser osxuser is offline
The proseal that the QB tanks use is probably the structural stuff that Cessna uses of it's tanks. Difference is the part one is pink, and the hardener is the same. It comes in the tubes that can be mixed with a machine and squeezed out like a tube of sillycone. Awesome stuff that.
Stephen Samuelian, CFII, A&P IA, CTO
RV4 wing in Jig @ KPOC
RV7 emp built
