Old 06-21-2008, 08:56 PM
detlef lili detlef lili is offline
Default No Audio from my GMA 347
Hello!
I have one GNS430W a VAL760CM and a GMA347. I wired all together and double checked the wiring. The intercom works perfect. Since I want to test the COM, I see only the RX and TX sign in the GNS-430W display but I hear nothing and my hand held transceiver shows me only the TX sign if I transmit and no voice.
What should I do at first?
Best regards
Detlef Heun
FAA A&P / EASA CFI
RV-7 N577DL 680 hours on Car Gas, sold
RV-7A N962JG 40h
Annual Fee 2016 proudly paid
Old 06-21-2008, 10:34 PM
Sticky1's Avatar
Sticky1 Sticky1 is offline
Default hummmmmm
Did u run the set-up software for the Garmin Audio panel....?
Old 06-21-2008, 11:42 PM
AltonD's Avatar
AltonD AltonD is offline
My understanding from Stark is that even if you do not want to change a single setting, you must run the setup software one time.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~900 hours since Aug 2010
N4IDH
Construction Log
“The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.”
Mark Twain
Old 06-22-2008, 08:10 AM
Thank you for the quick answer, to STICKY1, too!
I thought, that I have only to do this, if I want to change the settings later. I have no software to change the settings, where can I get it from?
I tried Garmin support, but I could not found an answer.
Best regards
Detlef
Detlef Heun
FAA A&P / EASA CFI
RV-7A N962JG 40h
Old 06-22-2008, 09:02 AM
AltonD's Avatar
check your email.
1. I have never used the software. Mine was setup by the avionics tech.
2. You will need to run out the serial conection from the 347.
Alton DeWeese
N4IDH
Construction Log
Mark Twain
Old 06-22-2008, 05:33 PM
Default I got the email
check your email.
Thank you Alton!
I got the email and will try it tomorrow.
Detlef
Detlef Heun
FAA A&P / EASA CFI
RV-7A N962JG 40h
Old 06-25-2008, 05:13 PM
Default It works!
Hi Alton!
The problem is solved. You must activate the settings.
Thanks again for your help.
Best regards and may be we will meet you anywhere.
Best regards
Detlef::
Detlef Heun
FAA A&P / EASA CFI
RV-7A N962JG 40h
