Old 03-03-2017, 04:35 PM
flyboy1963's Avatar
Default Fuel quick-drain lock DIY
nice part of a low-wing, easy to add fuel.
BAD part, easy to remove fuel!
I drained about 10 gallons by wedging a plastic jug with long spout, under my drain sump.
...now it would appears someone else has mastered the same technique....as I'm short pretty much a jug full!
There are commercial locks...and how do you make one that is tamper RESISTANT, but they won't get aggressive and wreck things trying to get it off?
well, this might keep the honest thieves out ( I'm thinking low-life pilots, fuellers, or whatever punks have a use for leaded hi-test????)
too small a lock, you can't slip it on...too big, it slips OFF. This little sleeve, and the safety wire make a decent fit...bit I'm sure with a concerted effort, it would pop off ( I hope) sparing actual tank damage.
oh, and then they head for the caps, where you might get all KINDS of contamination...so I'd rather they stole from the drains.
well....I rather they...well.....you know....!
Perry Y.
RV-9a - SOLD!....
kinda missing it!
Lake Country, BC
....paid up til Nov. 2018
Old 03-03-2017, 06:20 PM
SMRacer SMRacer is offline
Talking Oh, Canada!
We don't have those problems south of the border.
Jim
Leesburg, VA
RV4 N444JT (sold)
RV8 N37PK
Old 03-03-2017, 07:02 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Yes And bigger planes with bigger fuel tanks.
On your picture, can someone get a wrench behind the lock to take off the quick drain?
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1095+ hours
2018 Donation Paid
Old 03-03-2017, 09:10 PM
flyboy1963's Avatar
Default yes, and no
probably Dan, but that would remove the convenience of the 'hit and run' technique.
these guys jam the jug under the spring plunger....leave...then retrieve it later, we think, so removing the plug would make is much less, ummm, convenient? to drain anonymously. Perhaps they don't pack tools?
anyway, as I said, a concerted twist and tug, and it's off....but keep the honest thieves away!
Perry Y.
RV-9a - SOLD!....
kinda missing it!
Lake Country, BC
Old 03-04-2017, 04:27 AM
plehrke's Avatar
plehrke plehrke is offline
Can you use/mod an Aerolock throttle lock (fourth down on page) to keep from getting jug under the quick drain or maybe better lock the collar.
Philip
RV-6A - 12 years over 850 hours
Cessna 140 - 68 years over 3400 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 03-04-2017, 06:16 AM
moosepileit moosepileit is offline
Sounds uncommon and dumb, how about just get the degenerate arrested? Fences and recorded cameras an option?
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 03-04-2017, 06:42 AM
dtw_rv6 dtw_rv6 is offline
Default Would this be effective?
Maybe you just need an appropriate placard next to each drain:
https://drive.google.com/open?id=0B_...WE5QW1CS3FHUEk
Don
Old 03-04-2017, 07:21 AM
bobnoffs bobnoffs is offline
i think i agree with improving the environment. when he can't get anything out what will he put in?
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12.
RV-12 kit as of 9/13
Old 03-04-2017, 07:26 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Hangar
Sounds like a good reason to have a hangar!
Honestly though it is a sad situation. Almost any damage costs more than the fuel, but theft is theft. Play this situation out and you can't win. If you make the thieves mad, they could just poke a hole in the tank, etc. Pour sugar in the tank etc. Seems like finding the thieves is best. But best to not tell the public about how easy it is to steal or there will be copy cats.
FYI...a siphon hose thru the cap to a 5 gallon jug on the ground will work just as well as the drain....
I keep coming back to the Hangar........
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 03-04-2017, 08:21 AM
Weasel's Avatar
Weasel Weasel is offline
Just a thought
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1500hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
