I painted my plane and hope to never do it again.....I agree with the above except you can not sand the edges of base stripe if it has any metallic in it, if you can do it all with in the chemical bond window, 24 hrs for most base clear paint, no need for inter coat clear, I had problems when I tried this route, sanded it all down and re did the rudder, first part I did. with good paint, you can lay 3M striping tape on bare base coat after 30 minutes or so. I did my wing checkers different ....after wet sand primer, lay base black, then I used pro mask entire wing, draw and cut out checkers remove for next color, then spray next color, then I spray diagonal hint of very light highlight third color on diagonal intersection corners, and then shadow fourth color for 3D effect, pull remaining tape and clear X 2. on the fuse I did free spray where the line would be, then mask over that to keep, then border color, then mask that off, then spray final remaining color, remove ALL tape and clear X 2......Just for one part, like a wing, I spent a week of clean, scuff, clean, primer, sand, clean, primer, sand, clean. and then 14 hrs in one shot for the paint......on one part. then add complexity of flowing patterns to flaps tips and aileron, or the fuse, on and off the rotisary, on and off of the cowl, back on rotisary and so on.........thinking back.....I think I spent 2.5 years painting this thing......WOW! and its not even that good, by all means, if you have and extra 10-20K, have someone else do it ;-)
