Firewall temperature (engine side)
Hello everybody!
Has someone of you some hard facts (measurements) of the max firewall temperature (engine side) of a RV-14(A) with an IO-390 during normal operations?
Thanks a lot!
2017 subscription donation paid.
In my O-360 RV7 during 90*+ F outside air temperatures I see 165-175F on lower cowl temps in flight and around 215*F 10 minutes after a hot shutdown on the ground.
Can't speak for a 14, but I've measured exit temperatures in excess of 200F with my RV-8.
I've gone to a lot of trouble to ensure no air passes through the engine compartment without coming into contact with hot engine parts. The result is higher exit temperature; there is no dilution with cool air that leaked by the engine sealing.
meat thermometer
Not a -14, but I inserted a digital meat thermometer probe through the bottom of the firewall on my LNC2. The digital readout is where I can see it. It typically shows 140F in flight and has gone as high as 200 on a hot day after I land and am slow taxiing.
RV9A
Not a 14, but I have temp strips on the EarthX battery and the Pmags. Battery on the firewall sees 150 f and the Pmags on the back of the accessory case see 190 f.
hVNx7LPZCP63S4vZ1KUAyUMliBR92ch4kJQ0kxo8bb9H2Vc97y_-W9TUoQD8CqSerTHvGH8_ialem7SJrgt0B4KvgSDkOjgpXAGZr1KgERDWtOb_HGOcQ_mQ-Yq4_AiS4OFIGIcuAxnOjCBORondI77Q7cu1AUUB24Hc1JISvk71vnVQKmLXhvrc0Tnj17nNR1ZUtMpKbeEvmWyj6nFy1lTqP43uZRdoMGbp-kKbFgL8TIU46RG-EohLNlDoLfbGPC2-UN3wrTvFDsxxOY0YEFd_3sxSav3MJpBjWZLd27QicCVjbjji2AWFe8sXezCjl3dzmK6BvuH0HZk7tGFC5z6E5EfEELcqxnGoWdMG0PE3Iaau82mIxQoR7LZlB3ZC8xPh4Wca39r0EqiOf6wZtD6eHau7mU_qw_zjxINfLZYFwqCub0lP1QuwWL_8XTmwt-LGObrQzERMtHio7mIabLa4plqxbZ9b1gOqwZZn_rO1jc7bH51S15Z5a5ApmuXcRZOA1rYMT4xh9ONWG794Ckz3v3HS7CSxbcZdsUywsP9a5f0de5UjwkWPjI9SMCOLwI9wOaCz-wcayZKkPES0ZeYRCxDLuAf0aj9a9uHEVZZYp0728t2j=w693-h924-no
