Hello RV-7 2004,
I'm a tad confused, in your first post you said you 'have' a 2x but asked if you would 'need' a 3x. In another post you said you came across a good deal on a 2x with a push start and wanted to know if you should buy it?
You've already received a couple good replies but since you asked (and it's great therapy for my fingers) I'll ad my 2 cents.
Any-hoo - for me it's like this: I have the various 2X & 3X guns at my shop. I ALWAYS use my 2X. I simply don't like the 'break' between hits on the 3X, it's just too slow. Can I use it to build my RV....yes, but like Bill R. suggested...'when'...not 'if' you make a mistake, you'll wish you had the 2X. I've probably used just about every brand of rivet gun under the sun because when customers come to my shop they always bring their 'new', latest, greatest, cheapest, or most expensive rivet gun. In most cases it's a 3X and they bought it because they read on the forum that "it was the gun they 'had' to have". My favorite is the Avery 2X I bought to build my first RV. That same 2X rivet gun has built no less than 11 RV's and Rockets and I can count the times that I've oiled it on one hand
....and it hits like the day I bought it.
Yes the 3X can hit harder but again, it hits slower. Even when you dial it down for a shorty -3 it still doesn't have the nice smooth 'feel' of the 2X. If I had a 2X and a 3X and my 2X broke I'd go buy another 2X before I drove one more rivet, especially on skins. Bottom line is when the guys leave my shop they always wish that they had spent their money on the 2X after they learn how to use both guns.
I start new guys on a block of wood. Here they learn how to 'feel' and 'listen' to the gun and how to feather and squeeze the trigger. I use the little $15 dollar regulator from Avery on the gun. They learn that the rule of thumb is 3 clicks in and 3 clicks out between a -3 and a -4 rivet with the 2X gun. Once they can set the gun up for any rivet just by 'feeling' and 'listening' on a block of wood we move to our practice sheets of assorted -3 and -4 flush and universal rivets. They'll drive about a hundred rivets with various rivets sets/bucking bars while going back and forth between the 2X and 3X guns. By the time they leave they can rivet with their finger on the trigger and can also rivet 'inside/out' using their thumb on the trigger....very important. They also have to be able to switch left and right hands riveting and bucking solo. I've yet to have a customer choose the 3X over the 2X for setting these rivets once I showed them how it's done. Of course now that I've said that the next 5 guys will all want the 3X
A tad off the topic but I ALWAYS rivet in order of preference:
First preference -back rivet
Second preference -hand or pnuematic squeezer
Third preverence -rivet gun
Full circle, if you have the 2X on hand I suggest that you use it. If you feel that it's not driving the rivets for you and you 'want' a 3X then by all means go out and make the purchase.
The above is simply 'my experience' and others will most certainly disagree. Not a problem....what is important is that you practice, practice, practice and learn how set nice, clean, show quality rivets with the rivet gun that works best for you.
Hope this helps!
For the archives.
I have a 2X but will I still need a 3X to build a 7, or can I just build it with a 2X?
Rick,
I have to ask since you have done so much with these guns and the RV line. What is your favorite rivet gun for the RV’s? From what you said in your reply it would have to be a 2X, but which brand and model, trigger or push to start? I ask, because I’m just getting started with a RV7 tail kit and came across an excellent deal a new, unused, Atlas Copco (2X) it does not have a trigger, but is push to start. Will it serve me well on the RV7, or will I need to find a 2X with trigger in your view? Thanks to all for the responses and input?
