This is a question that I have never seen asked, which suggests it is not a problem. But it seems to me that it might be.
The VA-128 restrictor fitting that screws into the engine oil pressure port (the 45 degree fitting that has to be installed prior to fitting the engine to the mount) and that attaches the engine end of the oil hose going to the firewall mounted transducer manifold seems to run very close (3/16" clearance) to the right rear motor mount.
Is that a problem? I am of course concerned that engine movement might cause the fitting to contact the mount. Even though it is right at the mount, and so movement would not be as great as farther away, it seems awfully close.
There is a second engine port at 90 degrees to the one used (Aerosport installed the fitting) that faces directly rearward that would not have that clearance issue. Is that a port that can be used instead if the other one is a problem? I would have to remove the engine from the mount to change fittings.
Bill Brooks
Ottawa, Canada
RV-6A finishing
Bill Brooks
Ottawa, Canada
RV-6A finishing
