Old 12-20-2017, 07:12 AM
pa38112 pa38112 is offline
Default any P-mag pireps?
I am considering switching from Slick magnetos to P-mags. O-360-A1A with a FP prop. I am mainly interested in improving engine smoothness LOP. The cost savings of the 500hr maintenance on magnetos is a little addition justification. Has anyone done a similar conversion and like to share your impressions?
I am only interested in the P-mags because I don't want to add a redundant electrical system for other electronic ignition options.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 12-20-2017, 07:35 AM
Captdf Captdf is offline
4 years on dual Pmags. No problems, great factory support, straightforward install.
I operate LOP probably 75-80 percent of the time with an IO-320 and I can smoothly run as much as 70 degrees LOP.
With a carburetor maybe not so smooth LOP but you’ll still see savings by the ability to use auto plugs, smoother idle, easier starts and maybe a little less fuel burn at altitude ROP.
Dru Fisher
Cypress TX - KEYQ
RV-4, IO-320
Old 12-20-2017, 08:18 AM
dweyant dweyant is offline
2.5 years, 330 hours. They work great.
IO-320 CS prop. I run LOP anytime I'm at cruise and burn about 6.2 GPH at 145knots TAS in the 10-14k range.
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 12-20-2017, 08:52 AM
jbDC9 jbDC9 is offline
P-Mag reports/pireps? Yep! This question gets asked every other month...
Some light reading;
http://www.vansairforce.com/communit...ghlight=P-mags
John Bixby
RV-8 QB sn 82030 - 1575 hrs
O-360-A1D/CS/Pmags
New Waverly, TX
VAF donation Dec 2018
Old 12-20-2017, 09:59 AM
One additional PIREP to add to the pile. First flight was on Sunday. 1 impulse-coupled Slick, one P-Mag. No problems. Even EGTs / CHTs across the board at break-in power. Smooth-running.
Old 12-20-2017, 10:15 AM
Toobuilder's Avatar
Will have a nice pair of trouble free P-mags going on the market just as soon as Ross releases the CPI-2.
Michael Robinson
______________
Harmon Rocket II -SDS EFI instalation in work
RV-8 - Flying
1940 Taylorcraft BL-65 -flying
Old 12-20-2017, 10:48 AM
ChuckGant's Avatar
ChuckGant ChuckGant is offline
We are very happy with our P-Mags. After talking to the owner at Sun-n-Fun (Brad I think?) we switched to automotive spark plugs and saw a real improvement in starting performance, especially when hot. We were also able to run about .5 gal/hr leaner of peak than with the aviation plugs.
We have had no problems with them whatsoever. Highly recommend.
RV7 - N533CV
Based at Holly Springs, MS (M41), near Memphis, TN
The clouds beckon. I must go fly.
Old 12-20-2017, 12:34 PM
Some light reading;
Thank you for the links - very helpful. Do you know why I don't see these when I go to the Electronic Ignition Forum? There are only 4 or 5 post there.
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 12-20-2017, 12:48 PM
Ironflight's Avatar
VAF Moderator / Line Boy
You need to tell the search engine how far back to look - I think it defaults to 30 days. Set it all the way back, and you'll see way more information!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-21-2017, 12:26 PM
N941WR's Avatar
N941WR N941WR is offline
If you install P-mags, be sure to read and understand the manual and then install them accordingly.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
