Yes, there is certainly no risk of anyone describing our transponders as flimsy.
Garmin 250 watt remote mount mode S transponders including the GTX23ES used in experimental aircraft and the GTX33ES used for GX000 aircraft are used in tens of thousands of aircraft, including many jets, and are known for their solid design, performance, and reliability. The machined/cast enclosures are not light, but they certainly enhance the thermal performance of the unit.
Just for the record, below is the weight break-down of the GTX23ES.
GTX23ES transponder: 3.1 lbs
Connector and backshell: 0.4 lbs
Standalone rack (115-00629-00): 0.9 lbs
Many have commented on how pleased they are with the quality of the Garmin connectors and cast metal backshells, but as shown above, they aren't the lightest connectors you can find.
While the rack listed above comes standard with the GTX23ES, there is another available rack (115-00438-00 Modular rack) which weighs 0.4 lbs and saves 0.5 lbs on the installation that some use to install the GTX23ES. Please check with your dealer if you are interested in using the modular rack instead of the standalone rack.
Steve
