jjconstant
I was flying in cruise at 9500' for about 20 minutes, lean of peak, about 60% power and all egt's started rising and the engine got rough. When I went rich of peak everything seemed fine. I finished the flight, put the plane away and came back a few days later to see if I could reproduce the problem.
Start up was fine but during runup, when I did the mag check, #1 and #2 cylinders showed dramatic cooling off of EGTs (cold cylinders) on each individual mag check but when in the BOTH position everything was fine. Just to make it clear, Both position=everything good, Left mag=#1 and #2 are cold/not working and Right Mag= #1 and #2 cold/not working.
Fuel Injected, Dual PMags.
I took apart the key switch which is off/left/right/both NO start position and I could see no evidence of arcing or fouling. It looked pristine. I did a continuity check on the ground wire at the switch and it shows that when touching the other side of the DVM to anywhere on the airframe it shows continuity (beeps). I checked each individual ground on the wiring block at the back of the PMag that goes to the engine case and they appear solid.
I'm having a hard time accepting a simulataneous dual mag failure and one that takes out only 2 cylinders but the same two cylinders no matter which mag is isolated.
Any help with troubleshooting procedures would be very welcome. I haven't called Brad at emagair yet because I'm assuming he's swamped at Oshkosh. Thanks!
