MS19087
Installing the engine mount weldment on my QB 9A today. The QB firewall has 4 large pilot holes drilled on the four corners to accommodate the mount. After enlarging these pilot holes to the required 3/8" only 3 of the 4 line up readily - one (bottom rt) is off slightly. Is there a way I should finess this in place? The mount seems very rigid and not easily distorted. Any suggestions?Should I enlarge this hole? Or is my weldment just off a bit . . . Thanks!!
