Old 11-04-2018, 09:32 PM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Default Pink Cowl Seam Fit
Hi Fiberglass Gurus;
Now the cooler weather is starting to move back into my area, I started to turn my attention to reading, staring and mulling over the cowl fitting on my RV-7A. In the photos below, I think I have the top and bottom cowl somewhat in the position to clear my Whirlwind GA prop spinner (3/16") and close to finished along the firewall. However, the seam line between the halves gets progressively wider (open) as it proceeds forward to the spinner. Here some pics of where I am now;
I will be using Skybolt VLoc system along the firewall and the cowl halves seams. Since this area needs to be pretty strong, what recommendations and techniques should I use to build up this area that would allow me to install the Skybolt fasteners and maintain the "flushness" of the cowl seams and the the firewall? Or please point me to some past/current posts that have covered this particular topic. I did find some topics by Dan Horton but I just can not get a handle on how to apply them to this situation.
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Old 11-13-2018, 11:25 PM
snoopyflys's Avatar
Default Probable solution
Found this post by Dan Horton that should resolve my perceived problem. Thanks for posting this Dan
http://www.vansairforce.com/communit...ad.php?t=81595
Regards to all
Dan Schultz
VAF #1446
Old 11-14-2018, 07:09 AM
DanH's Avatar
DanH DanH is offline
Added a lost illustration to the above.
Regarding flanges and Skybolts, you may find this one helpful:
http://www.vansairforce.com/communit...d.php?t=124261
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-14-2018, 09:32 PM
wjb's Avatar
wjb wjb is offline
Dan, you're a treasure! I'm cowling now myself, and your posts are some of the most useful things I've read. Thanks for being so willing so share.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 11-15-2018, 07:36 AM
dwranda dwranda is offline
+1!! Awesome to have people like this to help the newbies.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Dec 18
