The a406 steel aileron bracket has a u-shaped cross section that is 7/16" wide. The 2 an3 bolts that hold it to the aileron are 3/8" across flats. All my 3/8" sockets are bigger in dia. than 7/16". How do you guts stop the bolts from turning so you can tighten the nut when there isn't enough space for a socket or a wrench?
