LotusSeven
Member
It seems that 22 years is about the on wing life span of the old style RV-4 wing tip lenses (YMMV). Both wing tip lenses are significantly cracked and crazed but just recently one finally failed completely. I am holding it on with something much like blenderm tape for now. It seems that Van's no longer sells replacement lenses for the old style of wing tip (Circa 1991). Does anybody know of a source for replacement lenses or does anyone have some after they upgraded to the new wing tips/landing light in the wing tip?
I may be forced to carve some plugs out of balsa and build a vacuum molding setup if I can source some and if that is the case I could probably make additional ones for people in a similar situation.
