Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 07-08-2019, 05:20 PM
bkervaski's Avatar
Default Garmin Virb Ultra 30 + G3X Touch + GMA245R Audio Panel ... Still a struggle
I really want to get this to work, seems like something simple ..
I still can’t seem to get any audio from my GMA-245R to record on the Virb.
I have the Virb paired to the G3X and the GMA-245R and the audio source on the Virb set to "External".
Are there other audio panel settings I’m missing?
On the G3X Phone screen it says “Recorder” with a green checkbox next to paired. On the Bluetooth screen the Virb shows up as “Unknown” but it does connect and I can control it via the panel.
Thanks for any help, seems like something simple that for some reason I can’t get past.
Edit: Wondering if I have a bad Virb or something at this point, does anyone else's show up as "Unknown" int he G3X bluetooth page?
Bill
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 07-08-2019, 05:30 PM
upperdeck upperdeck is offline
Default Virb to audio panel
I have my virb linked via Bluetooth to the Gma245, not to the G3X screen. Works perfectly.
Old 07-08-2019, 05:31 PM
bkervaski's Avatar
Would you mind stepping me through the procedure you used to pair it? Feeling pretty stupid about it at this point
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 07-08-2019, 05:37 PM
I don't recall actually, and I have the audio panel with buttons, not remote. Not certain what differences may be.
Old 07-08-2019, 06:29 PM
Nova RV Nova RV is offline
I have the 245R and Virb XE and have the camera linked to the audio panel only and it works fine. If I recall you just need the Virb bluetooth selected on then touch the "pair" button on the audio panel page in the G3X. I'm going to the plane tomorrow and can confirm this procedure but like was mentioned just need to pair the 245R to the Virb only.
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 07-09-2019, 09:33 AM
bkervaski's Avatar
Resolved! Thanks, G3X Team.
Ultimately it was that I had the camera paired with both the G3X and the audio panel. Removing the G3X pairing in the camera did it.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 07-29-2019, 08:53 PM
dmattmul dmattmul is offline
Default VIRB Power requirements
Since I'm almost finished my 14A and want to use the VIRB 30 with the powered mount. Since I'm using the 245R and Limo the aviation kit seems a waste of some accessories. Anyone know what's included in the aviation kit that's not in the Virb 30 powered mount model. Thanks !!
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, hope to be flying Spring of 2020 !! Dues paid+ of course !!
