Old 06-22-2019, 01:37 PM
paul330 paul330 is offline
Default Garmin G5 Fault
I am installing a G5 as a stand alone standby instrument. Eventually, I will have a magnetometer attached via the CAN buss but at the moment I have just attached power and fired it up.
I get the following indications:
- message saying "Hardware Fault"
- red X through the airspeed and "Airspeed Error"
- "Aligning" on the PFD which doesn't go away
I've looked through the install manual and can't find anything I should be configuring. Have I got an irrecoverable hardware problem or is there some way to fix this?
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 06-22-2019, 04:48 PM
RV7ForMe RV7ForMe is offline
Default Ask Garmin...
I would suggest you to ask Garmin expert team directly. at: g3xpert@garmin.com
They will help you out but you will have to wait for monday US time...
VAF dues paid until 10/2019
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 06-22-2019, 05:31 PM
Walt's Avatar
Walt Walt is online now
You may try pulling the red plugs if you have already done so.
Will it go into the setup menu?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-23-2019, 12:23 AM
The red plugs are out. I have the pitot and static tubes connected but the other ends are taped up. I guess it's possible that the "blockage" is causing the airspeed issue and that in turn is preventing the alignment - if the attitude relies on airspeed like the Dynon.
I'll check it out today and see if I can get into the setup menu and see what that might say.
Paul
2019 Donation Made
Old 06-23-2019, 05:20 AM
That was it. Guess pressure/temperature had changed so there was a negative pressure in the pitot tube or something. Anyway, all is well ......
Paul
2019 Donation Made
