Old 09-10-2018, 09:52 AM
Hartstoc's Avatar
Hartstoc Hartstoc is offline
Default Modification for assured tilt-up canopy jettison-
I’ve just launched into an aerobatic training program in my tilt-up RV-7A. After shelling out big bucks for the required parachutes, I began to wonder if the gas springs on my tilt-up could thwart or complicate an actual attempted bailout following a structural failure or mid-air collision. The thought of the potential injuries that could result from a flailing canopy still attached by gas springs to an aircraft tumbling out of control is disconcerting. I started a thread on this subject a while back, and a link to that is at the bottom of this post.
There are only three conditions during which the gas springs and their retainers are not subject to about 20# of compressive force: when the open canopy is struck by a gust of wind from behind, when the hapless pilot backs the airplane with open canopy into a partially closed hangar door, and when the canopy is jettisoned during flight.
Considering this, I elected to modify the excessively-sturdy 5/16” diameter anchoring bolts to include the breakaway feature described below. The trick was to keep them strong enough withstand the ocassional gust of wind from behind, but weaken them enough to break when subjected to an in-flight canopy jettison event. Photos with descripive captions of the modification I decided upon can be found here (9/23 edit: after the “ruthlessly helpful” suggestions and admonitions Appearing later in this thread, I concluded that I also needed to cut slots allowing the canopy hinges to depart directly upward during canopy jettison ;-). Photos and captions of this process have been added here as well.
https://public.fotki.com/Hartstoc/ca...e/?view=roll#1
Yes- this IS a purely intuitive modification that probably should be subjected to some calibrated destructive bench-testing to make sure it will behave as desired. Sometimes it just makes sense to trust ones intuition, so I’ll leave the bench-testing to others. Fortunately, the consequences of a fatigue failure of one of these bolts would not amount to more than an inconvenience, and I’ll report back if that ever happens. So far it is working fine. I hope we all have adopted the policy of never walking away from an RV with an open tilt-up. I’m especially attentive to that now!
Buy the way, I did try out the idea of simply removing the gas springs for aerobatics, but the challenge of getting in and out of the plane with a parachute strapped on your back while managing the unsupported canopy led me to promply discard this option.
Here is the link to my earlier thread on the topic. It also poses the question of whether it makes sense to just leave those expensive parachutes in the hangar when not doing aerobatics:
http://www.vansairforce.com/communit...anopy+jettison
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Frmr Test Pilot/Author CAFE APR's:
RV-8A, S-7C, Europa, Glastar.
-2019 VAF donation!!-
"RV-Fun is inversely proportional to RV-Weight!"
Old 09-10-2018, 11:42 AM
Bill Boyd's Avatar
Default Re: walking away with canopy open
I do it all the time. There's a doo-hickey that attaches to the lift strut and snaps into position when the strut extends far enough. Once in position it prevents the canopy from closing until it's manually pulled out of the locked position.
Having mistakenly trusted a set of slowly failing lift struts before, I wouldn't be without it.
The only way an idiot like me can defeat this idiot-proof device is by not assuring the canopy has opened far enough for the lock to snap into position before letting go.
On the jettison subject, I'm assuming you've slotted the forward deck skin over the hinge arms so they can come clear when the jettison handle is pulled. I removed my jettison T-handle when I realized the canopy would never jettison from a closed position without these special rainwater ingress slots cut.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 09-10-2018, 11:54 AM
Sam Buchanan's Avatar
been here awhile
The very early RV-6's used a prop rod instead of struts. You could remove the struts and resort to a prop rod.
A length of 3/8" fuel hose slit to allow it to be slipped over the strut rod accomplishes the same thing.
And yes, bad form to walk away from a non-secured tip-up canopy--only takes one strong gust of wind or an inattentive pilot to ruin your day.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 09-10-2018, 12:09 PM
Mel's Avatar
Mel Mel is offline
I recommend the original "Prop-Rod" solution. I never liked the struts.
And yes, you must have the slots cut above hinges. Cover the slots with 3-M tape and they will never be noticed.
A&P/BGI/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-10-2018, 02:10 PM
Hartstoc's Avatar
Thanks for the idea- If my breakaway bolts ever give me problems, I値l resort to the prop-rod idea, but it is kind of nice having the gas struts. Working on the slots now. - Otis
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Old 09-10-2018, 02:20 PM
I wonder if you could reduce diameter at the small end of the taper so the ball would pop off easier?
Hinckley, Ohio (1OA2)
EAA #499867
LSRM-A Certificate 2016
Old 09-16-2018, 05:30 PM
Hartstoc's Avatar
I知 still pondering this important comment, and I may yet cut these slots. For now, after studying the various posts on taking off with an unlatched canopy, or having a canopy inadvertantly unlatch in flight, I concluded that changing the bailout proceedure might make the slots unnecessary, especially if there are two people on board to help with canopy jettison.
If I did have the slots, my proceedure would be: 1- remove headsets. 2- check that center latch is engaged and leave it that way. 3- disengage primary latch. 4- pull jettison T- handle. This would hopefully make a pivot point put of the center latch, which would hopefully cause the canopy to do a clean back-flip as it departs.
In the absence of slots, my aerobatic instructor and I decided on this procedure instead: 1- remove headsets 2- disengage center latch. 3- disengage primary canopy latch while stabilizing canopy sides with the palms all free hands on board. The canopy should partially open and find an aerodynamic neutral point, but allow enough space for the it to slide aft and free the hinges when you: 4- pull the T-handle. For now, this is the proceedure that my instructor and I verbalize prior to boarding the aircraft before each flight. We also verbalize steps 5-7, 5- disengage seat belts. 6- Get your butt out of and away from the aircraft. 7- Visually identify the parachute D-handle, engage it with the thumbs of both hands if able, and push it briskly away from your chest with both hands. Having visualized your way through these proceedures just prior to each possible need to execute on them could save your life.
Of course, all bets are off if the aircraft is tumbling wildly out of control, which may be a fairly likely Scenario. In that case , there is just one item: Quickly find a way to jettison the canopy or open it sufficiently to fight your way out. You will at least have substantial motivation on your side! - Otis
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Old 09-16-2018, 06:08 PM
az_gila's Avatar
az_gila az_gila is offline
Post
With no slots, there might be a good possibility of the aft of the canopy floating upwards as the 'unlatched' folks have reported. Then what happens? The canopy may come straight back at you and hit you in the face.
The way Van originally designed it with the slots would seem to say the canopy would lift up at the front and do a back flip over the top, keeping it somewhat away from the occupants.
I'm sure Van considered the options in the initial design.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-16-2018, 10:04 PM
Hartstoc's Avatar
Well, given that the original design had slots and no gas springs, and virtually all tilt-ups now have gas springs and no slots, we are all in new territory. I致e certainly considered the possibility of being injured by the canopy, and I知 concerned about it. There is a good chance that I値l end up adding the slots to my plane. Until I do, as far as I can see, the exit strategy I described is the best availble. I知 not expecting to jump out of my airplane, but I知 pro-actively considering the possibility. I wonder if that can be said of the thousands of aerobatic hours that have been enjoyed in RV痴 with unmodified gas springs and no slots by others dutifully wearing the required parachutes?
I guess one additional step should be added to my current bailout proceedures- explore the possiblity of exiting through the unlatched but still attached canopy. Depending upon the condition of the aircraft, that just might work.
This is all intended as a discussion of the problem. I知 not yet suggesting that I have arrived at a reliable solution, but the great value of this forums is being able to include the thoughts of others such as you in the process.- Otis
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Old 09-23-2018, 10:39 AM
Snowflake's Avatar
There are other reasons for the change, though. The original -6 tip-up had arms that came straight back from the hinge points to the canopy frame. The slots were necessary to allow the canopy to open.
The design was changed at some point to have hook-shaped arms so the canopy could open without requiring slots in the fuselage. The hooks make ejection more questionable as they prevent the canopy from coming straight out and back... You now have to raise the back of the canopy far enough that the hooks can clear the panel.
Although i've removed and installed my canopy frame a couple of times, I don't recall how far the rear has to be raised to slide it back. Maybe I should try that.
Rob Prior
