N546RV
So I'm in the process of deconstructing my horizontal stab after a botched SB attempt. Tonight I was working on removing the rear spar. Got the skin rivets and solid skeleton rivets drilled out and removed. For the four BSPQ-5-4 rivets attaching the rear spar to the main ribs, I drove out the mandrels and drilled far enough to take off the rivet heads. However, the spar still isn't coming off, thanks to those rivet shaft apparently having a good solid grip on the spar bars.
Clearly the shafts need to be driven out to release the spar here, but I'm trying to figure out the best way to do this without potentially damaging the hole. Since the rivet shaft is just a tube, the only option here seems to be putting a small punch against the edge of the hole in the spar bar and punching the shaft out that way - but this seems like a really good way to bugger up the hole.
Is there some magic trick I can use here, or is it just a "be careful" type of situation?
